Definately size of PMOS is 3 times larger than NMOS.
So mobilty is 1/3 of NMOS.
iIn General Crital Path is largest distance frm I/P to O/P, Reg to O/P,Reg to Reg.,I/p to Reg.You need to reduce the Critical Path by including FF.
Hi..
As I understand question was regarding PMOS size in SRAM cell.
As PMOS size is decreased in SRAM the stability of SRAM cell decreases.
As per the critical path in SRAM I would suggest that it is not straight forward.
There are 2 paths which are in race.
1.. Clock to Row Selection
2. Clock to Precharge switch off.
So, the path which constitutes more delay will be Critical path in this case.
In case you find this useful, I will request you to click on helped me icon.
hi nitu,
wat i said before is the universal concept,.
The critical path in an SRAM is the Read Operation. The bit line has to be discharged thro 2 transistors in series. Devices have to be sized to prevent the intermediate node from charging up too much. For the write operation, all constraints are automatically met by a large margin.
CRITCAL PATH determines the max. freq of operation.:idea:
