kaiserschmarren87
Member level 4
I have understood what CRC algorithm is. I found enough information online. Also found online tools to generate VHDL code for the specified data and polynomial. Could someone be generous to explain how the data and crc bits are chosen for CRC generation in this VHDL code generated from this webpage: **broken link removed**
I know that the CRC is obtained from the polynomial given from which a Linear Feed Back Shift Register realization will yield the required CRC as shown below (just for example but not specific to the VHDL code given above).
I just need the logic behind XOR operation GIVEN IN THAT VHDL CODE which helps for parallel CRC operation as per the below documents:
1. http://outputlogic.com/my-stuff/parallel_crc_generator_whitepaper.pdf
2. http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.75.387&rep=rep1&type=pdf
I have implemented CRC Generation and Detection from the general XOR operation but it takes more clock cycles. So I had to rely on parallel CRC generation technique.
-- CRC Engine RTL Design
-- Copyright (C) www.ElectronicDesignworks.com
-- Source code generated by ElectronicDesignworks IP Generator (CRC).
-- Documentation can be downloaded from www.ElectronicDesignworks.com
-- License
-- This source file may be used and distributed freely provided that this
-- copyright notice, list of conditions and the following disclaimer is
-- not removed from the file.
-- Any derivative work should contain this copyright notice and associated disclaimer.
-- This source code file is provided "AS IS" AND WITHOUT ANY WARRANTY,
-- without even the implied warranty of MERCHANTABILITY or FITNESS FOR A
-- PARTICULAR PURPOSE.
-- Specification
-- File Name : CRC8_DATA16.vhd
-- Description : CRC Engine ENTITY
-- Clock : Positive Edge
-- Reset : Active High
-- First Serial : MSB
-- Data Bus Width : 16 bits
-- Polynomial : (0 2 3 4 8)
-- Date : 16-Jun-2015
-- Version : 1.0
LIBRARY IEEE ;
USE ieee.std_logic_1164.all ;
USE ieee.std_logic_arith.all ;
USE ieee.std_logic_unsigned.all ;
ENTITY crc_gen IS
PORT(
clock : IN STD_LOGIC;
reset : IN STD_LOGIC;
soc : IN STD_LOGIC;
data : IN STD_LOGIC_VECTOR(15 DOWNTO 0);
data_valid : IN STD_LOGIC;
eoc : IN STD_LOGIC;
crc : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
crc_valid : OUT STD_LOGIC
END crc_gen;
ARCHITECTURE behave OF crc_gen IS
SIGNAL crc_r : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL crc_c : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL crc_i : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL crc_const : STD_LOGIC_VECTOR(7 DOWNTO 0) := "00000000";
BEGIN
crc_i <= crc_const when soc = '1' else
crc_r;
crc_c(0) <= data(0) XOR data(4) XOR data(5) XOR data(6) XOR data(13) XOR crc_i(5) XOR data(15) XOR crc_i(7) XOR data(10) XOR crc_i(2);
crc_c(1) <= data(1) XOR data(5) XOR data(6) XOR data(7) XOR data(14) XOR crc_i(6) XOR data(11) XOR crc_i(3);
crc_c(2) <= data(0) XOR data(2) XOR data(7) XOR data(8) XOR crc_i(0) XOR data(12) XOR crc_i(4) XOR data(4) XOR data(5) XOR data(13) XOR crc_i(5) XOR data(10) XOR crc_i(2);
crc_c(3) <= data(0) XOR data(1) XOR data(3) XOR data(8) XOR data(9) XOR crc_i(1) XOR crc_i(0) XOR data(14) XOR crc_i(6) XOR data(11) XOR crc_i(3) XOR data(4) XOR data(15) XOR crc_i(7) XOR data(10) XOR crc_i(2);
crc_c(4) <= data(0) XOR data(1) XOR data(2) XOR data(9) XOR crc_i(1) XOR data(12) XOR crc_i(4) XOR data(11) XOR crc_i(3) XOR data(6) XOR data(13) XOR crc_i(5);
crc_c(5) <= data(1) XOR data(2) XOR data(3) XOR data(10) XOR crc_i(2) XOR data(13) XOR crc_i(5) XOR data(12) XOR crc_i(4) XOR data(7) XOR data(14) XOR crc_i(6);
crc_c(6) <= data(2) XOR data(3) XOR data(4) XOR data(11) XOR crc_i(3) XOR data(14) XOR crc_i(6) XOR data(13) XOR crc_i(5) XOR data(8) XOR data(15) XOR crc_i(7) XOR crc_i(0);
crc_c(7) <= data(3) XOR data(4) XOR data(5) XOR data(12) XOR crc_i(4) XOR data(15) XOR crc_i(7) XOR data(14) XOR crc_i(6) XOR data(9) XOR crc_i(1);
crc_gen_process : PROCESS(clock, reset)
BEGIN
IF(reset = '1') THEN
crc_r <= "00000000" ;
ELSIF( clock 'EVENT AND clock = '1') THEN
IF(data_valid = '1') THEN
crc_r <= crc_c;
END IF;
END IF;
END PROCESS crc_gen_process;
crc_valid_gen : PROCESS(clock, reset)
BEGIN
If(reset = '1') THEN
crc_valid <= '0';
IF(data_valid = '1' AND eoc = '1') THEN
crc_valid <= '1';
ELSE
crc_valid <= '0';
END IF;
END IF;
END PROCESS crc_valid_gen;
crc <= crc_r;
END behave;
