could somebody help me about creating or using memory field at FPGA
tryingsth
Junior Member level 2
Hello,
I'm new at FPGA and I'm trying to make a project with this. According to my my project I must use a memory on FPGA. Because I'm calculating the average of integers which are comes at 1 clk pulse. From 6*6 matrix I must get 9 integer numbers one by one and I must calculate the average and then I save this average in a new matris. But I get an error about getting integers at 1 clk. As I said I'm beginner so I need your helps.Could you have any idea? Thanks.
moottii
Full Member level 2
In VHDL or Verilog?
Is your memory 2 Dimensional or 3D?
I didn't understand what your project is, but I can tell you how to write a memory.
tryingsth
In VHDL or Verilog?
Sorry I forgot tell them. In VHDL for now I have 6*6 matrix and I try to apply avering filter. So I need a memory but I'm new at FPGA and I don't know using or creating memory and its dimension. I need help.Could you explain detailed?
moottii
Full Member level 2
Well
First of all you should know the architecture of memory. You've got to be familiar with concept of I/O of the memory such as input data, address, output data and etc.
In simple word, Memory is a collection of registers, which can hold the required data and is able to transfer data IN and OUT of itself.
But for better understanding You need to search on the web to realize these concepts.
Then, you are will be able to encounter HDLs (like VHDL) and write code for your project.
This can be a good point to start
tryingsth
Well
really thank you so much. Technically I get lessons about a memory but I have no practice. I want to ask sth. As I understand FPGA has own memory. And I must use this. Am I wrong? Can I directly use the memory? Or I have to write a code which works like memory.
I can ask silly thinks. I apologize for this :-(
moottii
Full Member level 2
It depends on your synthesis tool. In the old versions of synthesis tool, there were some "written" codes in synthesis tools and you had to instant those available written codes.
But in newer synthesis tools, there is no need to do this. You can write your own memory and synthesis tools support it.
Now you have to concentrate on learning "Memory Architecture" as I mentioned before.
You're welcome. It's not silly at all. Every person, who starts learning, encounters these kinds of problems. Don't feel ashamed at all.
tryingsth
thank you. I'm working on it.I hope I'll overcome this. Thanks again and again. :)
