Corrugated Trapezoidal Structure in HFSS
alamin_iut
Hi All,
I am trying to carry out eigen mode solution upon a corrugated trapezoidal structure. I used metal and it shows solving inside a solid with high conductivity may require a large mesh in hfss. I have applied master slave boundary condition, want to carry the sim using metal. since i have a corrugated structure the whole objects became one. "not checking solve inside" is not of help. mesh operations should be defined. i need help badly.
i want to find out the reflection profile of a trapezoidally corrugated slow wave structure. for that i have to excite the structure with a antenna.how do i do that?
here i want to add some image of the designed structure
You can excite the structure with an incident plane wave for the general case. Use an antenna if you need a specific setup, but the simulation will be much larger.
for finding the reflection profile of the structure from resonance peaks i have to short the both sides with metal. what type of antenna should i use?
Is it possible to find the s11 parameters if i use incident wave for excitation
I'm not sure what you mean. Short both sides of what?
Yes. You need to insert a measurement plane. (Scattered Real Power/ Incident Real Power) integrated over this plane (for power normal to the plane, obviously) will give you the square of S11.
i am attaching one image of the arrangement here. by short i meant that i have to short the both ends of the structure as i want the reflection profile.
May you please elaborate on measurement plane.
Any surface, really -- a square sheet should do. For best results, surface normal in the direction of propagation, and the sheet completely covers the cross-sectional area of the waveguide.
I'm not sure what you're expecting to get out of this test, though. Won't the power always be completely reflected?
