Is there an easy way to correlate surface current density data with corresponding magnetic field data in 3D...
I can easily get access to both but there is no correlation of indexes...
I understand that H is used to calculate the surface current on PEC bounders but to get the H for the given current one must search entire H 3D volume and find appropriate
3D position which matches the current position...
In short H is both surface and air/vacuum and current is surface only...
I need to correlate in order to calculate Lorentz force surface density in frequency domain and not in eigenmode...
