eem2am
Banned
op amp offset
Hello….
It is known that op-amps give slightly inaccurate output voltages due to …..
1) Input bias currents
2) Input offset
So, I realise that an op-amp has an input offset that means that when used with negative feedback, its output voltage will not be zero when it has zero volts between its inverting (V-) and non-inverting (V+) inputs.
I am aware that this offset is gotten-rid-of by using a pot at dedicated “offset-null” pins…..OR by putting some high value resistor between the positive supply of the op-amp and the inverting input.
Also…
… I am aware that an op-amps V+ and V- inputs draw input bias currents….and that these bias currents create voltages at the inputs, since they flow through whatever resistors are biasing the op-amp……
..in order to mitigate this problem with an inverting op-amp, a resistor of value R(feedback//R(in) is put from V+ to ground.
…..However, in reality, the op-amps “input offset” is actually caused by the fact that the op-amps “input bias currents” are actually NOT equal…(?).
…so in actual fact, “input offset” is just another problem caused by “input bias currents”. (?)
As such, if I want to mitigate (get rid of) these bad effects, then surely I only need to use ONE of the above correcting steps?……
…in other words……rather than use a resistor from V+ to ground AND the offset-null pot……….-I can simply just use the offset-null pot to deal with both the “input bias current” problem and the “input offset” problem.
Do you believe this is correct?
Thankyou for reading.
Hello….
2) Input offset
Also…
