converting mikro c codes to mplab
clarence501
Junior Member level 3
Philippines
Sirs, Madams, I have found a progarm for 1hz clock generator and I want to test it. But it's using mikro C codes and I'm only familiar with mplab codes and I don't know how to convert this codes. Here they are:
// PIC12F675
// 1Hz Time Base Osc.
// Timer1 Module
// 32.768 KHz
unsigned short tick;
void Init ();
void interrupt ()
if (PIR1.TMR1IF)
TMR1H = 0xE0;
PIR1.TMR1IF = 0;
tick = 1;
void main ()
tick = 0;
//Initialize Ports and Timer1 Module
Init ();
while (1)
if (tick)
tick = 0;
GPIO = (1 << 2);
if (TMR1H > 0xF0)
GPIO = 0;
void Init ()
TRISIO = 0;
//Make all pins as output ports
GPIO = 0;
//Use Timer1 module
INTCON.GIE = 1;
INTCON.PEIE = 1;
T1CON = 0x01;
//Overflow every 8192
TMR1H = 0xE0;
TMR1L = 0x00;
// Enable TMR1 interrupt
PIE1.TMR1IE = 1;
I hope somebody can help me with this. Thanks in advance. I'm still a beginner with programming.
I hope someone can help me solve this problem. Please, just even help me with translating this codes, so that I can practice in doing it in MPLAB.
Try this
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
// PIC12F675
// Timer1 Module
// 32.768 KHz
void Init ();
void interrupt ()
    if (PIR1bits.TMR1IF)
        TMR1H = 0xE0;
        PIR1bits.TMR1IF = 0;
        tick = 1;
void main ()
    tick = 0;
    Init ();
    while (1)
        if (tick)
            tick = 0;
            GPIO = (1 << 2);
        if (TMR1H > 0xF0)
            GPIO = 0;
void Init ()
    TRISIO = 0;
    GPIO = 0;
    //Use Timer1 module
    INTCONbits.GIE = 1;
    INTCONbits.PEIE = 1;
    T1CON = 0x01;
    TMR1H = 0xE0;
    TMR1L = 0x00;
    PIE1bits.TMR1IE = 1;
still has a lot of errors when i try to build this all in mplab sir. Where do I start with making a code for 1hz generator using mplab?
there seems to be no difference in the codes sir
Maybe you are getting errors for TRISIO and GPIO if you are using PIC16F or PIC18F. Which PIC are you using? Which Toolsuite are you using with MPLAB to Compile the Code?
Code by Lahman Marcel for Hi-Tech C Compiler.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
// PIC12F675
// Timer1 Module
// 32.768 KHz
#include <htc.h>
void Init ();
void interrupt isr ()
TMR1H = 0xE0;
tick = 1;
void main ()
tick = 0;
Init ();
while (1)
if (tick)
tick = 0;
GPIO = (1 << 2);
if (TMR1H > 0xF0)
GPIO = 0;
void Init ()
TRISIO = 0;
GPIO = 0;
//Use Timer1 module
INTCONbits.GIE = 1;
T1CON = 0x01;
TMR1H = 0xE0;
TMR1L = 0x00;
Im using the Hi Tech C compiler. But still has a lot of errors sir.
