erfan.khalilian69
Member level 4
- Joined
- Feb 7, 2011
- Messages
- 71
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,288
- Location
- Kualalampur
- Activity points
- 1,916
Hi everyone
I need to control the washing machine using PIC microcontroller :
The following are the design considerations to be followed:
1. Set the time using a DIP switch (maximum value is 99 seconds)
2. The setting values should be displayed on the seven segment display
3. The spin process should begin when the start button is pressed and then
START the Motor (LED ON)
The display value on the seven segments should start counting down
4. When the value is zero, STOP the motor (LED OFF)
5. Also modify the spin timer by increasing or decreasing the rotational speed
plz help me over this, thanks
