NOTSam
Newbie level 1
- Joined
- Apr 23, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 28
I am trying to control two Futaba S3003 servo motor with a basys2 board. I understand that the servo works of pulse width modulation and have done the required calculations to create the correct pulse widths.
I have written the implementation constraints to output on the the JA and JB terminals. I have tested the system with an oscilloscope/multimeter and have not been able to detect any output on the pins. Can anyone help me understand what I am doing wrong?
Here is my setup
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity Final_v1 is Port ( tup : in STD_LOGIC; tdown: in STD_LOGIC; gclose : in STD_LOGIC; gopen : in STD_LOGIC; reset : in STD_LOGIC; grip : out STD_LOGIC; clk : in STD_LOGIC; tilt : out STD_LOGIC); end Final_v1; architecture Behavioral of Final_v1 is constant period:integer:=1000000; constant dcycle_max:integer:=100000; constant dcycle_min:integer:=50000; constant duty_in:integer:=200; signal tilt_reg,tilt_next:std_logic; signal grip_reg,grip_next:std_logic; signal gduty_cycle,gduty_cycle_next:integer:=0; signal gcounter,gcounter_next:integer:=0; signal tduty_cycle,tduty_cycle_next:integer:=0; signal tcounter,tcounter_next:integer:=0; signal gtick:std_logic; signal ttick:std_logic; begin --begin grip process(clk,reset) begin if reset = '1' then grip_reg<='0'; gcounter<=0; gduty_cycle<=0; elsif clk='1' and clk'event then grip_reg<=grip_next; gcounter<=gcounter_next; gduty_cycle<=gduty_cycle_next; end if; end process; gcounter_next<= 0 when gcounter = period else gcounter+1; gtick<= '1' when gcounter= 0 else '0'; --Changing Duty Cycle process(gclose,gopen,gtick,gduty_cycle) begin gduty_cycle_next<=gduty_cycle; if gtick='1' then if gclose ='1' and gduty_cycle >dcycle_min then gduty_cycle_next<=gduty_cycle-duty_in; elsif gopen ='1' and gduty_cycle < dcycle_max then gduty_cycle_next<=gduty_cycle+duty_in; end if; end if; end process; --Buffer grip<=grip_reg; grip_next<= '1' when gcounter < gduty_cycle else '0'; --end grip --Begin tilt process(clk,reset) begin if reset = '1' then tilt_reg<='0'; tcounter<=0; tduty_cycle<=0; elsif clk='1' and clk'event then tilt_reg<=tilt_next; tcounter<=tcounter_next; tduty_cycle<=tduty_cycle_next; end if; end process; tcounter_next<= 0 when tcounter = period else tcounter+1; ttick<= '1' when tcounter= 0 else '0'; --Changing Duty Cycle process(tup,tdown,ttick,tduty_cycle) begin tduty_cycle_next<=tduty_cycle; if ttick='1' then if tup ='1' and tduty_cycle >dcycle_min then tduty_cycle_next<=tduty_cycle-duty_in; elsif tdown ='1' and tduty_cycle < dcycle_max then tduty_cycle_next<=tduty_cycle+duty_in; end if; end if; end process; --Buffer tilt<=tilt_reg; tilt_next<= '1' when tcounter < tduty_cycle else '0'; --end tilt end Behavioral;
Here is my setup
