Control led by writing a string serially into microcontroller
shubham156
Sir, i want to control room devices by transmitting serially from virtual terminal to microcontroller.
That means if i write BULB ON in virtual terminal, the bulb connected to p0.0 glows
I have written a code but that is not working fine.
Please can you tell me the errors in this.
I am attaching the code and circuit diagram.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
#include<reg51.h>
sfr ldata=0x90;
sbit rs=P2^0;
sbit rw=P2^1;
sbit en=P2^2;
void delay();
void lcdcmd(char value);
void lcddata(char value);
void main()
unsigned char p[40]="BULBON";
unsigned char q[40];
unsigned int i=0;
unsigned int flag=0;
unsigned char mybyte;
P1=0;
lcdcmd(0x81);
delay();
lcdcmd(0x0E);
delay();
lcdcmd(0x01);
delay();
lcdcmd(0x06);
delay();
TMOD=0x20;
TH1=0xFd;
SCON=0x51;
TR1=1;
while(1)
while(RI==0);
mybyte=SBUF;
while(mybyte!=0x20)
q[i]=mybyte;
if(p[i]==q[i])
    flag=1;
i++;
if((mybyte==0x08)||(mybyte==0x7f))
lcdcmd(0x01);
lcddata(mybyte);
if(flag==1)
P0=1;
RI=0;
delay();
ldata=value;
rs=0;
rw=0;
en=1;
delay();
en=0;
ldata=value;
rs=1;
rw=0;
en=1;
delay();
en=0;
void delay()
int i,j;
for(i=0;i<256;i++);
for(j=0;j<256;j++);
Circuit diagram:
That is extremely tedious. A far better solution is to copy your incoming characters to a buffer then 'strcmp' them with the commands.
You can then add more commands, for example "BULBOFF" easily.
Store the characters from the Serial buffer into an array or using a pointer. And then use the strcmp commands or strncmp (if you intend to compare particular length of character)
Based on the comparison result go for toggling the I/O pins.
I have attached the code for your concept. Check this. I haven't compiled the code. If you find any errors, post it.
  • 8051-lcd.txt
