Hi All,
No answer, but solution found anyway...
Following command should be used before any setup of UPF:
set upf_create_implicit_supply_sets false
Also you need to specify operating conditions. These can be found by report_design command.
Here is complete set of commands which is able to properly connect single power:
create_power_domain TOP -include_scope
create_supply_net TOP_VDD1 -domain TOP
create_supply_net VSS -domain TOP
set_domain_supply_net TOP -primary_power_net TOP_VDD1 -primary_ground_net VSS
create_supply_port VSS -domain TOP -direction in
create_supply_port TOP_VDD1 -domain TOP -direction in
add_port_state VSS -state {state1 0.000000}
add_port_state TOP_VDD1 -state {state1 1.080000}
connect_supply_net VSS -ports VSS
connect_supply_net TOP_VDD1 -ports TOP_VDD1
set_voltage 1.08 -object_list { TOP_VDD1 }
set_voltage 0 -object_list { VSS }
set_operating_conditions WCCOM
compile_ultra
write -pg -hierarchy -format verilog -output file_synth.v
