CONNECTING FAX MODEM CARD WITH PIC
rehan
Junior Member level 1
HI,
Anyone has experience of using pc modem card with pic?
Rehan
a RS232 serial port and AT command can work.we use a RS232 convert interfce to a 8051,then can control the modem with AT command.i think PIC is same way.hope this can help you.
REGARDS!
shanren
Hi Rehan,
If PC modem card is on PCI, well that's an overkill aplication for PIC micro.
If it's on ISA, it could work but you still need to provide the drivers for the chipset included on ISA board. If it's just for fun it's a chalenge for you to try. But if you intended something for mass production, my advice is to try an embedded modem. I know it's not cheap as modem card, but you can't find forever ISA boards, which are obsolete.
You can find embedded modem on manufacturers like:
**broken link removed** Connexant shape compatible
You'll have full support for AT commands through serial interface.
Just fit on your development board and play.
Regards,
Silvio
