sam781
Full Member level 4
- Joined
- Oct 22, 2011
- Messages
- 212
- Helped
- 7
- Reputation
- 14
- Reaction score
- 7
- Trophy points
- 1,298
- Activity points
- 2,757
I've made a bridge Converter and an Inverter.
Converter: 12v to 400v dc (practically measured using DMM after applying filter)
Inverter: Sine PWM inverter. Checked output using 12v supply. output is not that much good. but I want to check with higher volt (400v).
Now, to get both the circuits (converter and inverter) work I'll have to have a common ground. how can I connect the converter control circuit's ground to the output (400v) ground?
