sfchew7
Junior Member level 2
Computer driver problem or voltage problem ?
I have programmed the right code to my pic16f877a, I can use putc/printf function but I failed to use getch function.
I couldn't receive any data from pc to my PIC16f877a when using my own computer but when I used my friend's computer, it can transmit the data from his PC to my PIC16f877a.
I have using max 232 IC, rs232 db9 femal pin, and also usb to rs232 converter.
The circuits and the coding are the same.
So, what will be the problems?
thanks
thanks
