Computer controlled IR remote control
tarang
Junior Member level 3
Hello folks,
I am working on my final year project which is a speech recognition.
I want to design an IR device that can communicate with the TV or other IR receiver. This device will be connected to the PC.
As you all might know that serial and parallel ports are fading out now...So i want to interface this device to PC using USB.
Can anyone guide me how USB programming works(pref in MATLAB)...and what will i need on the device for USB connection?
thanx....
btbass
Advanced Member level 5
Oberon
Unfortunately, usb programming is not trivial. The universal serial bus is hot plug and play and can work with a massive variety of different devices. When you plug in your usb device, it goes through a process of enumeration that describes to the pc what it does and what driver the pc should load. Device descripters can be quite complex.
One solution for you would be to use a pic microcontroller for the usb interface. You can download a usb stack, free from Microchip, that has a lot of example code for the pic and the pc interface. You should be able to modify the code from the examples to do what you require.
tarang
Thanx i will look on to it....
