alpha86
wireless composite video
Hie I am quite new to electronics and I'm doing a circuit to transmit composite video by wireless.
So far, I have found that this device can do it all :
AWM 630 TX
https://www.dpcav.com/xcart/product.php?productid=16177
and its counterpart receiver AWM 634 RX
Question:
1. I would like to know how to interface the AWM630 with the antenna. Can i use a surface mount antenna like this?
https://www.johansontechnology.com/images/stories/ip/rf-antennas/Antenna_2450AD46A5400.pdf
If possible, how should the connection be like?
2. So am i correct to say that I could tapped the video from a composite and connect to the AWM630 and the video will be transmitted through the SMD antenna?
3. Is there other alternative? or cheaper ones? Can I send the video using VHF or UHF freq and get the video directly from TV? Is there such a small antenna (Surface mount) for these freq?
Sorry for the info, the Tx / Rx device I need will be very near each other (just need a short range) but the device is small (need small antenna)!
Hope you could help me clarify all the doubts. Thanks
AWM 630 TX
Question:
