Register Log in
Complex measurement problem
pixel
Advanced Member level 2
This is one practical measurement problem. I have resistor divider Rs, Rp and capacitance Cp in parallel with Rp, connected to gnd.
Here are circuit equations:
Iin = Vin*(1+s*Cp*Rp)/(Rp+Rs+s*Cp*Rs*Rp)
Iin = Vin*(Rp+Rs+Rs(wCpRp)^2+jw*Cp*Rp*Rp)/((Rp+Rs)^2+(w*Cp*Rs*Rp)^2)
v[Cp]=v[Rp]=(Rp*Vin)/(Rp+Rs+s*Cp*Rs*Rp)
i[Rp] = v[Cp]/Rp
i[Cp]=v[Cp]*s*Cp
Input admitance: Y=Iin/Vin=A(w)+jB(w)
I can measure only admitance vector Y (or Iin), i.e. A(w) and B(w) values at frequenciues w1 and w2. How can be Rp, Rs and Cp identiified ?
tom_hanks
Full Member level 5
Rp and Rs are frequency independent component...
so they are easy to identifed
using current divide formula
while for CP you need use this formela
find out >
VC1 at freq=w1
VC2 at freq=w2
Cp=(Vc1-Vc2) * Y
pixel
I can not measure voltage at output, because I dont have acess. Such case is for example in some biomedical measurement, or chemical process. Only I can measure is input current amplitude and phase at some frequency. If you write equations you will see that it is not so easy, but also quite interesting task to find solution.
teteamigo
Portugal
We should know the greatness order of Cp, to apply a frequency that made impedance of Cp equal to ZERO.
Measure Input resistor in this condition.
Then measure current DC
Calculate Rs and Rp
The Cp may be calculate by measure the time constant-ζ (ideal for Cp higher) of transient response. Or then by made the RC series equivalent of parallel Rp//Cp, then you can use the ressonance frequency criterium to determine Cp.
tom_hanks
Full Member level 5
It s look ery tricky...
i guess u need to use a Frequency and wave generator...
and see the responce of input change....
and find out the resonant frequency...
with resonant frequency u can get the component values..
tom
pixel
I have found one method... Here Y is differentaiated, and gives more suitable equations, but problem is how to measure accuratelly dY/dw... Doeas anyone have some simpler solution?
tomhive
Member level 2
why u wants to know the individualy RS,RP & C, once u have input Admt. or current mag. if u cant acces to those.
tomhive
bye
pixel
Because thoose values are important characteristics of some electrochemical process.
Borber
Advanced Member level 5
on third flor
We have 3 unknowns. We need 3 equations to solve the problem. If you measure Y at 3 frequencies you have those 3 equations.
    pixel
pixel
I have at first also had such idea, but I could not solve equations...
maybe question for math forum... I think that they are not independant...
Element_115
First do a DC measurement.
Say @ 1Vdc, find the current ?mA--> then Rs+Rp = 1v/?mA! (C is Open at DC)
Now use a Funtion Genorator and put a sine wave into the circuit.
Increase the frequency until you get a maximum current! At this point
you can "Assume" the Cap is a short. Now if you can get the AC current
you can find out what Rp is.
Rs = Vac/Iac
Rp = (Rs+Rp) - Rs.
Now get a nominal frequency and calculate C.
1Vrms (@ Fo) /Iac = Rs+ [(Rp*2piFoC)/( Rp*2piFoC)]
Vac is known, Iac measured, Rs&Rp calculated---> Solve for C
Cheers
zorro
Argentina
Actually, there are 3 unknowns and 4 equations: A(w1), B(w1), A(w2), B(w2). The problem can be solved as a "best fit". The system can be ill conditioned: for instance, if B<<A for both frequencies, C cannot be practically calculated.
Pixel, can you choose the 2 frequencies?
Regards
Z
    pixel
pixel
Regards
Z
I can choose two frequencies between zero and pole in current characteristics, but I can not measure DC, or too high frequencies.
Toggle Sidebar
