compile verilog in cadence
sambhav007
Junior Member level 1
I want to know how to compile a verilog file and simulate the design.
Thanks,
Sambhav
If you already have the verilog file ready, then
1) To compile verilog file, just use the command "verilog <File name>" if you have verilogXL else use the command "ncverilog <File name>" if you have ncverilog
2) To simulate the verilog file you need a test bench. It should contain all the vectors for which you want to simulate the design.
regards
Chethan
Hey
I have previous experience with cadence tools
Kindly tell us your problem in detail and then I can help u
Thanks.! i'll try that out.. and yeah, oncei write the test bench, i need to compile it in the same way right? and how to siimulate my test bench? is it all command interface only isnt there a graphical interface for doing the same?
the command for simulating ur verilog test bench is same. both ncverilog and verilogxl have graphical interface. U need to invoke them in ur test bench. ur test bench shd contain all vectors for which u want to see if functionality is correct.
to invoke the gui tool of cadence, you should write "simvision" in your shell
The commands verilog, ncverilog, simvision do not work.. it says command not found.. probably i need to do the setup.. can anybody tell me what setup i need to do before i can use verilog xl or ncverilog..
