If you already have the verilog file ready, then
1) To compile verilog file, just use the command "verilog <File name>" if you have verilogXL else use the command "ncverilog <File name>" if you have ncverilog
2) To simulate the verilog file you need a test bench. It should contain all the vectors for which you want to simulate the design.
Thanks.! i'll try that out.. and yeah, oncei write the test bench, i need to compile it in the same way right? and how to siimulate my test bench? is it all command interface only isnt there a graphical interface for doing the same?
the command for simulating ur verilog test bench is same. both ncverilog and verilogxl have graphical interface. U need to invoke them in ur test bench. ur test bench shd contain all vectors for which u want to see if functionality is correct.
The commands verilog, ncverilog, simvision do not work.. it says command not found.. probably i need to do the setup.. can anybody tell me what setup i need to do before i can use verilog xl or ncverilog..
