Compile Nangate45 library with Synopsys' Library Compiler
thomas.whatsoever
Newbie level 2
I am trying to compile the Open Cell Nangate45 Library with the Synopsys Library Compiler. By searching how to do this I came across the instruction from **broken link removed**. According to this it should basically work like this:
1. Starting Synopsys Library Compiler
$ lc_shell
2. Within Library Compiler read .lib file and write as .db file
read_lib library.lib
write_lib library -format db -output library.db
However, if I try this with the unmodified NangateOpenCellLibrary_functional.lib (from the PDKv1_3) I get the errors and warnings you can see below. Does somebody has an idea what could be the problem and how to solve this?
Best regards,
Thomas
Error: Line 48, Cell 'AND2_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 76, Cell 'AND2_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 104, Cell 'AND2_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 132, Cell 'AND3_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 165, Cell 'AND3_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 198, Cell 'AND3_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 231, Cell 'AND4_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 269, Cell 'AND4_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 307, Cell 'AND4_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 345, Cell 'ANTENNA_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 365, Cell 'AOI211_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 403, Cell 'AOI211_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 441, Cell 'AOI211_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 479, Cell 'AOI21_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 512, Cell 'AOI21_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 545, Cell 'AOI21_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 578, Cell 'AOI221_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 621, Cell 'AOI221_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 664, Cell 'AOI221_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 707, Cell 'AOI222_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 755, Cell 'AOI222_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 803, Cell 'AOI222_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 851, Cell 'AOI22_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 889, Cell 'AOI22_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 927, Cell 'AOI22_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 965, Cell 'BUF_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 988, Cell 'BUF_X16', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1011, Cell 'BUF_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1034, Cell 'BUF_X32', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1057, Cell 'BUF_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1080, Cell 'BUF_X8', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1103, Cell 'CLKBUF_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1126, Cell 'CLKBUF_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1149, Cell 'CLKBUF_X3', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1172, Cell 'CLKGATETST_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1224, Cell 'CLKGATETST_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1276, Cell 'CLKGATETST_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1328, Cell 'CLKGATETST_X8', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1380, Cell 'CLKGATE_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1424, Cell 'CLKGATE_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1468, Cell 'CLKGATE_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1512, Cell 'CLKGATE_X8', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1556, Cell 'DFFRS_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1610, Cell 'DFFRS_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1664, Cell 'DFFR_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1710, Cell 'DFFR_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1756, Cell 'DFFS_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1802, Cell 'DFFS_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1848, Cell 'DFF_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1888, Cell 'DFF_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1928, Cell 'DLH_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1962, Cell 'DLH_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 1996, Cell 'DLL_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2030, Cell 'DLL_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2064, Cell 'FA_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2103, Cell 'FILLCELL_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2119, Cell 'FILLCELL_X16', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2135, Cell 'FILLCELL_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2151, Cell 'FILLCELL_X32', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2167, Cell 'FILLCELL_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2183, Cell 'FILLCELL_X8', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2199, Cell 'HA_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2233, Cell 'INV_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2256, Cell 'INV_X16', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2279, Cell 'INV_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2302, Cell 'INV_X32', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2325, Cell 'INV_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2348, Cell 'INV_X8', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2371, Cell 'LOGIC0_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2392, Cell 'LOGIC1_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2413, Cell 'MUX2_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2446, Cell 'MUX2_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2479, Cell 'NAND2_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2507, Cell 'NAND2_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2535, Cell 'NAND2_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2563, Cell 'NAND3_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2596, Cell 'NAND3_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2629, Cell 'NAND3_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2662, Cell 'NAND4_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2700, Cell 'NAND4_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2738, Cell 'NAND4_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2776, Cell 'NOR2_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2804, Cell 'NOR2_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2832, Cell 'NOR2_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2860, Cell 'NOR3_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2893, Cell 'NOR3_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2926, Cell 'NOR3_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2959, Cell 'NOR4_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 2997, Cell 'NOR4_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3035, Cell 'NOR4_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3073, Cell 'OAI211_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3111, Cell 'OAI211_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3149, Cell 'OAI211_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3187, Cell 'OAI21_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3220, Cell 'OAI21_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3253, Cell 'OAI21_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3286, Cell 'OAI221_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3329, Cell 'OAI221_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3372, Cell 'OAI221_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3415, Cell 'OAI222_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3463, Cell 'OAI222_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3511, Cell 'OAI222_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3559, Cell 'OAI22_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3597, Cell 'OAI22_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3635, Cell 'OAI22_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3673, Cell 'OAI33_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3721, Cell 'OR2_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3749, Cell 'OR2_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3777, Cell 'OR2_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3805, Cell 'OR3_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3838, Cell 'OR3_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3871, Cell 'OR3_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3904, Cell 'OR4_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3942, Cell 'OR4_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 3980, Cell 'OR4_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4018, Cell 'SDFFRS_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4085, Cell 'SDFFRS_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4152, Cell 'SDFFR_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4211, Cell 'SDFFR_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4270, Cell 'SDFFS_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4329, Cell 'SDFFS_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4388, Cell 'SDFF_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4441, Cell 'SDFF_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4494, Cell 'TBUF_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4523, Cell 'TBUF_X16', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4552, Cell 'TBUF_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4581, Cell 'TBUF_X4', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4610, Cell 'TBUF_X8', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4639, Cell 'TINV_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4668, Cell 'TLAT_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4708, Cell 'XNOR2_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4736, Cell 'XNOR2_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4764, Cell 'XOR2_X1', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Error: Line 4792, Cell 'XOR2_X2', The 'drive_strength' attribute cannot be specified here. (LBDB-76)
Warning: No 'time_unit' attribute has been specified for the
	library. This attribute is needed in technology libraries. (LBDB-238)
Warning: No 'capacitive_load_unit' attribute has been specified for the
Warning: No 'pulling_resistance_unit' attribute has been specified for the
Warning: No 'voltage_unit' attribute has been specified for the
Warning: No 'current_unit' attribute has been specified for the
Warning: Line 33, The attribute 'slew_lower_threshold_pct_rise' is not specified. (LBDB-605)
Warning: Line 33, The attribute 'slew_upper_threshold_pct_rise' is not specified. (LBDB-605)
Warning: Line 33, The attribute 'slew_lower_threshold_pct_fall' is not specified. (LBDB-605)
Warning: Line 33, The attribute 'slew_upper_threshold_pct_fall' is not specified. (LBDB-605)
Warning: Line 33, The attribute 'input_threshold_pct_rise' is not specified. (LBDB-605)
Warning: Line 33, The attribute 'output_threshold_pct_rise' is not specified. (LBDB-605)
Warning: Line 33, The attribute 'input_threshold_pct_fall' is not specified. (LBDB-605)
Warning: Line 33, The attribute 'output_threshold_pct_fall' is not specified. (LBDB-605)
The liberty format is a nightmare, tools have been half-assing support for it for years. I think you got some attributes in the .lib that library compiler cannot process.
