Samran
Newbie level 3
- Joined
- Dec 23, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 44
VHDL: Comparison between vectors
Hi all,
I'm working on simulating a VHDL design using a self-checking testbench. As part of the error checking, I compare two values: one that is the expected value and one that is the received value. Both of these values are 16-bit std_logic_vectors and are members of arrays of 32 entries.
In the design, I send out a value that is then sent back through other means. The sent value comes from TriggerInArray(0) and the received value is read in to TriggerOutArray(0). I then compare TriggerInArray(0) and TriggerOutArray(0) and print "success" or "failure" and the expected and received values. In this test, I expect and receive the 16-bit hex value 0025, but for some reason the 0025 in TriggerInArray(0) does not equal the 0025 in TriggerOutArray(0).
Code excerpt:
The output I see in the simulation is as follows:
To answer a couple potential questions about the code I omitted:
Thanks in advance for any help! I'm officially stumped on this one.
Hi all,
Code excerpt:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 use IEEE.numeric_std.all; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; use IEEE.std_logic_textio.all; use std.textio.all; procedure CheckTriggers is variable TriggerInArray : STD_ARRAY; variable TriggerOutArray : STD_ARRAY; variable val : std_logic_vector (15 downto 0) := x"0000"; variable bval : boolean; variable mask : std_logic_vector(15 downto 0) := x"0000"; begin **Stuff to send values** --Retrieve values: -- for j in 0 to 15 loop mask := std_logic_vector(ieee.numeric_std.to_unsigned(2**j, 16)); bval := IsTriggered(x"60", mask); val := std_logic_vector(shift_left(ieee.numeric_std.unsigned(to_std(bval)),j)); TriggerOutArray(0) := TriggerOutArray(0) or val; end loop; writeline(output, msg_line); write(msg_line, STRING'("Trigger 0 received: ")); hwrite(msg_line, TriggerOutArray(0)); writeline(output, msg_line); if TriggerInArray(0) = TriggerOutArray(0) then write(msg_line, STRING'("SUCCESS: Expected ")); passtemp := passtemp + 1; else write(msg_line, STRING'("FAILURE: Expected ")); failtemp := failtemp + 1; end if; hwrite(msg_line, TriggerInArray(0)); write(msg_line, STRING'(", received: ")); hwrite(msg_line, TriggerOutArray(0)); writeline(output, msg_line); end procedure CheckTriggers;
Trigger 0 received: 0025
FAILURE: Expected 0025, received: 0025
- IsTriggered is a function that checks a particular bit on the incoming value. It returns a boolean.
- to_std is a function I wrote to convert a boolean value into a 16-bit std_logic_vector
- In this design, I use both numeric_std and std_logic_arith. This is necessary because of the way other pieces of the program work and I cannot omit one or the other (I tried and it broke a part of the program that I'm not allowed to change).
