compare with don't care condition in VHDL
yuenkit
std_match
1. if i want to do somthing like casex in verilog, what should i do?
2. is std_ulogic type synthesizable?
3. i wish to make a look up table.
part of the my code is something like
case A is
when "1---" => out <= "0001"
or
i should introduce an immediate variable
var <= A & "1000";
case var is
when "1000 => out <= "0001"
which one is better?, pls give suggestion. Thanks
vhdl std_match
There is case in VHDL if you want to use process. Also, you can make conditional assignments outside of process, using keyword "when".
Yes. The special table is used to re-compile 9 possible values of std_ulogic to '0', '1' and 'X'.
case A is
Wrong! Don't care ('-') of std_logic is different with classical idea of don't care.
yuenkit said:
or
var <= A & "1000";
Depends on compiler. Some old synthesizers can introdice additional AND stage, which is not necessary.
yuenkit said:
case var is
This one will work OK. Every synthesizer simplifies logic of case statement. Also, you can try to use "if" statement.
Also, I would recommend you to read manual of your synthesizer - most of these questions are answered there.
std_match vhdl
Hi!
You can also use std_match function from ieee.numeric_std package
below is example code from my design .It is an priority encoder
if std_match(dane_24(23 downto 0),"-----------------------1")then
decoded<="00001";
elsif std_match(dane_24(23 downto 0),"----------------------1-")then
decoded<="00010" ;
elsif std_match(dane_24(23 downto 0),"---------------------1--")then
decoded<="00011";
elsif std_match(dane_24(23 downto 0),"--------------------1---")then
decoded<="00100";
elsif std_match(dane_24(23 downto 0),"-------------------1----")then
decoded<="00101";
elsif std_match(dane_24(23 downto 0),"------------------1-----")then
decoded<="00110";
elsif std_match(dane_24(23 downto 0),"-----------------1------")then
decoded<="00111";
elsif std_match(dane_24(23 downto 0),"----------------1-------")then
decoded<="01000";
elsif std_match(dane_24(23 downto 0),"---------------1--------")then
decoded<="01001";
elsif std_match(dane_24(23 downto 0),"--------------1---------")then
decoded<="01010";
elsif std_match(dane_24(23 downto 0),"-------------1----------")then
decoded<="01011";
elsif std_match(dane_24(23 downto 0),"------------1-----------")then
decoded<="01100";
elsif std_match(dane_24(23 downto 0),"-----------1------------")then
decoded<="01101";
elsif std_match(dane_24(23 downto 0),"----------1-------------")then
decoded<="01110";
elsif std_match(dane_24(23 downto 0),"---------1--------------")then
decoded<="01111";
elsif std_match(dane_24(23 downto 0),"--------1---------------")then
decoded<="10000";
elsif std_match(dane_24(23 downto 0),"-------1----------------")then
decoded<="10001";
elsif std_match(dane_24(23 downto 0),"------1-----------------")then
decoded<="10010";
elsif std_match(dane_24(23 downto 0),"-----1------------------")then
decoded<="10011";
elsif std_match(dane_24(23 downto 0),"----1-------------------")then
decoded<="10100";
elsif std_match(dane_24(23 downto 0),"---1--------------------")then
decoded<="10101";
elsif std_match(dane_24(23 downto 0),"--1---------------------")then
decoded<="10110";
elsif std_match(dane_24(23 downto 0),"-1----------------------")then
decoded<="10111";
elsif std_match(dane_24(23 downto 0),"1-----------------------")then
decoded<="00000";
end if;
Regards Martin (PL)
vhdl dont care
xlnx said:
Hi!
				decoded<="00001";
				decoded<="00010" ;
...skipped...
				decoded<="00000";
end if;
And what should be assigned to signal "decoded" in case when all bits of "dane_24" are 0? You will get unnecessary latches, just because you missed one possible value: "all 0".
As to priority encoder, I would prefer combinational statement, like this:
decoded <= "00001" when dane_24(0) = '1' else
          "00010" when dane_24(1) = '1' else
          "10111" when dane_24(22) = '1' else
          "00000";
vhdl casex
Yes of course my fault
it should be:
decoded<="00000";
else decoded<="00000";
end if;
Regards Martin (PL)
Added after 23 minutes:
Ace-X I have little offtopic question :
Are any restrictions to check priority on signal edge?
Checked signal is stable long before and long after this edge,
or rather I should use some level sensitive logic?
dont care in vhdl
Priority encoder is pure combinational logic, so it just encodes currrent input value. It is up to you how you will latch/sample its output.
hi
can u pls send me vhdl code to compare n bytes like for ex:
101010101 compared with 10101000
