Compact Microstrip Antenna - IEEE Paper
drasko
Member level 2
What results differ? Radiation pattern or return loss?
I can not open your hfss file since I'm still using v9.
hkprakash7
Member level 1
Hi drasko,
Both the return loss and the gain don't match!! I don't know how to down-convert HFSSv10 to HFSSv9.. if there is way to do it that is.
Its a pretty simple geometry actually. If you can build it in HFSSv9 and see if it works, it would be of a great help.
Thanks,
-Prakash
shameemkabir
Full Member level 4
Hi Prakash,
I've seen your design. There is nothing wrong with that I guess however, you can use smaller substrate.
What I understood from the paper, the authors didn't simulate the structure but got the results by experiment. You can also build such a structure to see whether you get the same results.
It is written in the paper "Impedance matching is achieved by changing the length of arm 1 and frequency tuning by adjusting the length of arm 2". You can also change these two to find expected behaviour.
regards,
shameemkabir
    hkprakash7
hkprakash7
Member level 1
Hi Shameem,
I did try sweeping over Substrate Thickness and the arm lengths and widths... Nothing seems to work. I wonder how they could get it to work when its not even simulating correctly. I mean its not even close to the simulated results.
Any further thoughts on improving the simulation setup???
Thanks,
-Prakash
