arunbhaskar said:Hello. I'm very new to the world of PCB design. I came across many terms related to PCB on the internet. Can someone clearly explain what each term means. If possible please provide explanation with pictures. The terms I came across are:
1)Component side
2)Solder side
3)Gerber
4)Via
5)Drill
6)Pads
7)Silkscreen
Also tell me if I need to know a few more terms related to PCB. Thanks.
Yes..when one knows thoroughly more about PCB, then one may use the terms like A, B and so on. But for a beginer who is learning the various terms used in PCB designing, "Component Side" and "Solder Side" will fit the best.jmatt said:Instead of "Component Side" and "Solder Side", many folks are using terms like "Side A" and "Side B" or "Primary" and "Secondary" or (less commonly) "Top" and "Bottom".
keith1200rs said:Never heard "side A" and "side B"...
Keith.
