ali8
Member level 2
I have an almost squared thin film with 4 contacts along the corners. Using 4-probe measurement, I can eliminate the contact resistance. On the other hand, Whetstone bridge can be used to record resistance noise as a function of time (because the balanced bridge will have zero output voltage, so any fluctuation is considered noise). The problem is that Wheatstone bridge requires a 2-terminal sample, or a 4-terminal one with the resistances of the two halfs being equal, which is not the case here.
Is there any Wheatstone-like bridge that can incorporate 4-probe measurements as well?
