valdorf
Junior Member level 1
Hello everyone,
currently I am designing a circuit that can shift a voltage level from 3.3V 200kHz PWM signal to 36V PWM (an ultrasonic transducer). This ultrasonic transducer consumes only 10-20mA max at 36V.
I do not know if this is best solution, but I think about using H-Bridge like I found one DMHC10H170SFJ https://www.diodes.com/assets/Datasheets/DMHC10H170SFJ.pdf which has small surface mount package, low Rds(ON), more than enough Drain-Source Voltage.
As I understand correctly, I should convert 3.3V to at least 10V for Vgs? The problem is that I do not have additional power supply like 10V, but only 3.3V, 5V and 36V. What would be solution to control this H-Bridge with 3.3V PWM input?
