code C for conncetion of gyrocompas in FPGA
didaSET
Newbie level 3
Newbie level 3
how to add i2c on MicroBlaze EDK
hello
I need your help I want to connect a gyrocompas(HMC5883L) with a microblaze which is done by I2c and as microblaze does not have the bus I2c. I must add it as a peripheral to the microblaze but I do not know how in EDK
regards
Re: how to add i2c on MicroBlaze EDK
In case your your gyrocompas(HMC5883L) has a I2C and the microblaze does not, then you need to do a bus protocol conversion. A traditional way to do this is to use a protocol conversion bridge. So if your microblaze is using ABC protocol, then you need to design a ABC-to-I2C bridge and add it to the Microblaze.
I'll see it thank you
hello
Someone has already work on the code for the conncetion of gyrocompass HMC5883L with MicroBlaze in 3AN FPGA
