coaxial feeding for a bowtie antenna
prateek3790
Full Member level 2
i am following this paper.
in this since there is no substrate is used i assumed the thickness of the antenna to be like a plane. now i want to feed using coax then the bottom surface is connected to ground snd the upper triangular shape has been connected to the feed. on doing this i am getting the error - needs terminal between 1 and 25.
also is it possible to bend the structure in hfss. i have used a simple triangular sheet instead of using the bend structure.
regarding the feed :
- i made a hole of rad = 1mm on the ground , made the inner conductor of the coax to be 1mm. and connected this to the tip of the triangles.
- substrate rad = 2mm (did subsrate - inner conductor with cloning)
- outer conductor rad = 2.5mm (did outer conductor - substrate with cloning) connected to ground.
  • 05996567.pdf
uploaded the design. not made a bend geometry
  • bow_te_antenna_uwb.zip
ok I was able to solve that error but th e actual paper has a geometry that is bend (curved surface) . So is there a way by which it is possible to this in hfss? I am not able to find any option in hfss
