CMOS Opamp Slew Rate measurement
rishabh_31ec
Member level 1
Member level 1
Hi, I have Designed a 4-stage CMOS Opamp with +/- 0.85 Volt rail to rail supply and obtained the Bandwidth as 4.2 MHz. In order to measure the SLEW-RATE, should I have to apply a step voltage of peak values as ( V+ = 0.85 & V- = -0.85 v ).
I have a confusion regarding width of Step.
I think frequency of Step should be less than Unity Gain Bandwith. Am I right or I can choose any frequency of Step.
One hint is to look into datashhets of opamps and to see how the manufacturerst test this.
Voltage level: I expect different slew rate depending on input levels. With large voltage and high dV/dt the input stage may be overdriven causing varying slew rate.
Hope this helps
Klaus
rishab, the slew rate is an indication of the opamp´s ability to follow a positive (or negative) step. Do you expect any influence of the time the input stays at the final level ?
Hence, you can use any repetition rate of the step function (squarewave) - as long as the width of the step function is sufficient to allow the output to reach the final value.
