hi can you give some important parameters like
gain, UGF, load cap., pwr. supply, max. curr. consumption, necessary matching accuracy resp. max. offset, process size ...
It depends on your offset and noise requirement.
The pmos loading pair mismatch and noise will be reduced by gmL/gmI. gmL is gm of loading PMOS. gmI is gm of input NMOS.
