sharkies
Member level 5
CML frequency divider
I was working on a CML frequency divider, and realized that it doesn't work for low frequencies, 1GHZ and below, or 100MHz for example. It works when I pull up the frequency to 1GHz and above. Does a CML frequency divider have a lower frequency bound? cause this just sounds weird. Afterall, it is two D flips connected together.
I need a divider for roughtly 700MHz, any suggestions? perhaps TSPC will do the job?
thanks
thanks
