I'll work on this with you - PM me. Basically you need an H-bridge which is pretty simple to make, just some big mosfets (30000/0.5).
If you don't want to worry about break-before-make and all the other driver tricks, you can use an H-bridge driver IC and just feed it a logic signal from your controller.
