Circuit diagrams of class A audio amplifier
darklord4
Junior Member level 3
I need to build a class A audio amplifier with the following specifications
Output power: (1,3,5) W output through an (4,8) Ω load
Frequency response: ± 0.5 dB from 100-15 kHz
Efficiency:efficiency greater than 30 % maximum (when the ouput is dc)
I dont have much idea regarding amps, any help appreciated, say a ckt diagram.
Any help appreciated
Re: class A Audio Amp
thanks for the above mentioned links
I need help understanding the ckt
mainly what help are the resistors R3, R6, R7, R9, R10
and capacitors C6 and C7
Added after 1 minutes:
https://obrazki.elektroda.pl/74_1216280321.gif
this is the link for the image
R3 provides dc bias for Q1 (from voltage divider R1/R2) ..
R6 (alone) dc feedback to Q1 ..
R6/R7/C6 ac negative feedback, where C6 just cuts off dc component ..
In other words, R6/R7 set the amplifier’s gain ..
R10 works like a fuse ..
R8/R9 set dc condition for the dynamic load based on Q2 ..
And that should be it ..
Rgds,
IanP
Could you please elaborate on the role of R8, R9
Thanks
Added after 19 minutes:
also whats the exact role of Q2 and Q3
Q2 seemed to be somekind of a stable current source
Q3 seemed to provide more gain
is my reasoning correct?
