chopper stabilized opamp pss simulation problem
iamxo
Full Member level 4
Full Member level 4
Southeast Asia
vco pss simulation
from cadence help doc, it is said pss and pnoise can simulate chopper stabilized opamp noise.
so I use this to simulate my design. my design has an on-chip osc.
but when simulating, the pss function (oscillator) doesn't converge well, it often fails.
if I remove the osc circuit, and add an ideal clock, then the pss function works.
so, if I don't want to remove the osc circuit, and I want to simulate noise , how can I do with it ?
thanks all.
My osc frequency is low 100kHz, and the pss function often gets the fundamental frequency away from 100kHz, such as 46kHz, 60kHz.
the oscillator option is for real oscillator circuits which is not ur case, so u need to unselect it and put ur own clock generation model
but my circuit has an osc part, if I unselect the oscillator option, how did pss do with the circuit?
what do u mean by osc part? do u have something like ring osc. or vco ?
yeah, My circuit has a Gm-C oscillator, it supplies the clock signal. so, when I do pss simulation, I select the "oscillator" option, then it doesn't converges always, just like what I said before.
