sankposh
Junior Member level 3
I have a ferrite transformer with folowing details:-
input voltage 12-0-12 V,
input resistance 0.099E-0-0.099E
input inductance 5.7 uH-0-5.6 uH
output voltage we design to get around 4KV,
output resistance 1.835K
output inductance 455.1mH/455.2mH
center tapped, pulses of 12 volt 20
KHz will be applied to each winding sequentially like push pull
transformer.
Wave form of 12Volt 20KHz input --- these waveforms are in the form of
pulses with 50% duty cycle.
Input Frequency.- Max 20 KHz
Output we required 4 KV with load
in 500 to 1000 Ohms
I wanna check the output voltage as dirctly we cant check bcoz its in KV
suggest me a circuit externally we can check
we could apply a resistor divider?
MOD: Do not use "Upload temp to post querrys. Post in respective forum sections. Read announcemnets/ rules prior posting. Now the thread is moved
transformer.
in 500 to 1000 Ohms
