firejim
Junior Member level 3
- Joined
- Aug 13, 2011
- Messages
- 26
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,452
It has 2 halogen lights 20w and I first bought one circle led like this:
It worked! one halogen and one led and worked! I bought again another led to avoid heat of halogens, but when I tried both leds like this didn't worked.. it just flashes
So I tried another led that I thought It could be better, like this:
It didnt worked either. I am new to electronics so I open the kitchen hood (it's Neff) to see what power supply uses:
It has a NF40 Electronic Transformer for low voltage lamps the specs are:
PRI: 220-240VVac 50-60Hz 0,18A
λ=0,98
SEC: 11,5-12,5Vac 20....40W 3,5A max wires min 0,75mm^2
and last Dimmable by trailing edge dimmer
So is there any solution that I can use in both sides led or only a combination with halogen?
λ=0,98
