I didn't know that voltage could "flow". I guess you mean that current flows. It flows the whole way round through R2, doesn't affect the battery, zero amps there.
Please save the pic as png next time. Jpg pictures is not suitable for chematics. It got a redicilus filesize and looks ugly. A png version would probably have a filesize below 10 kb.
The cap will act like a voltage source with its positive terminal at A.
The current actualy flows from C to A, but for all practical calculations we say it flows from A to C. The same is true for the battery, the current actually flows from + to -, but we say it flow from - to +(called Conventional current).
If you consider like curent is in opposite the direction of flow of electrons.So, when switch moves to point C then across capacitor A us at positive potential and B is at ngative potential .so in closed loop current flows from A to C but if you RE TALKING ABOUT convenional current it flows from B to A.
Initially when the battery was connected to the capacitor through R1 for a long time the capacitor will be charged to the voltage of the battery 12V. Now when theswitch position is changed so as to allow the capacitor to discharge through R2 the initial voltage at the point C wil be 12V. Then the voltage across the capacitor will decrease esponentially with the relation V(t) = 12exp(-t/[R2*C]). The current through the loop will decrease from 12V/R2 with the expresion V(t)/R2.
2)We say that the electric current flows the same direction as the positive charge carriers do and the opposite of that which negative charge carriers do. In the given schematic that is from A to C to B (when the switch moves to C the source V1 and resistor R1 do not affect the situation). Electrons are negative charge carriers, so they will flow to the opposite of the A to C to B direction (that is B to C to A), while holes which are positive charge carriers travel the same way as the current. In general one can consider the electric current flowing to the opposite direction of that which electrons do
The transient behavior of a circuit with a battery, a resistor and a capacitor is governed by Ohm's law, the voltage law and the definition of capacitance. Development of the capacitor charging relationship requires calculus methods and involves a differential equation. For continuously varying charge the current is defined by a derivative
