Matze
Newbie level 2
Hi, I'm currently working with the Altera DE2 board. To get started with it and the Quartus Software I've implemented a simple circuit using an open source IP-Core (PacoBlaze). The board provides two clock inputs, a 27MHz one and a 50 MHz one. For the first time implementing the design (timing constraints: 50MHz) I used the 50MHz clock and it worked perfectly. Then I tried to use the 27MHz clock and the design didnt work at all. The pushbuttons I used as an entry didnt have any effects on the outputs.
So now I'm wondering why it works with one clock but not with the other. I couldnt find that there is anything special with the 27MHz clock in the manual. Has anybody an idea what the reason for this could be?
Thanks in advance!
Thanks in advance!
