cannot open macro file: system.do
mahound
Newbie level 5
Newbie level 5
Hi
I am a beginer for modelsim. I made a project as microblaze. then I wanted to simulate it.
I run modelsim through this command: make -f system.make sim
Then I run 4steps for simulation. the first step is : do system_setup.do;c
but this step cannot completely run and give an error : # cannot open macro file: system.do
"system" term is name of my project.
please help me
thanks
A .do file in modelsim is a run script having a collection of modelsim commands (required to compile,load and run the design). It might also be a set of signals which have to transferred on to the wave window(in which case you have to run it after the simulation is run). This file is missing in your setup.
make sure you're in the same directory as system.do
type "pwd" to see current path.
