chenobi
Hi everyone im still learning to use vhdl and FPGA. I wanted to try to make a lifo system and this is the code I made:
compiling works fine, but when i try to simulate it doesn't show the whole test i used in the do-file. It only shows
up to 1000 ns simulation time instead of the 2300 ns total time.
when i looked for a problem it showed this:
# ** Warning: (vsim-8780) Forcing /lifov3/nrst as root of /lifov3/b2v_inst/nrst specified in the force.
# ** Warning: (vsim-8780) Forcing /lifov3/d_in as root of /lifov3/b2v_inst/d_in specified in the force.
# ** Warning: (vsim-8780) Forcing /lifov3/count_down as root of /lifov3/b2v_inst/count_down specified in the force.
# ** Warning: (vsim-8780) Forcing /lifov3/count_up as root of /lifov3/b2v_inst/count_up specified in the force.
# Cannot continue because of fatal error.
# HDL call sequence:
# Stopped at C:/Users/leon-/Documents/elektrotechniek jaar 2/Periode 3/digitaal 3/Practicum lifo V3/lifo_datapath.vhd 40 Process data_processing
when i looked at which place it refers too i found that it said something about this line in my vhdl
stack_mem(stack_ptr) := d_In;
My question is did i do something wrong when writing that line? It seemed fine to me. And also how should i solve this problem?
note: I do not have a testbench or rather i always just tested using do file and looking for answers on the internet if I found
a problem or error.
note2: I also looked here at forums with similar problems and the only thing i can think of is my mem_type being too small
But not sure i what i think is right or not
Used do-file
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; ENTITY lifo_datapath IS PORT ( clk : IN std_logic; d_in : IN std_logic_vector (3 DOWNTO 0); nrst : IN std_logic; count_down : IN std_logic; count_up : IN std_logic; d_out : OUT std_logic_vector (3 DOWNTO 0); empty_signal : OUT std_logic; full_signal : OUT std_logic ); END lifo_datapath; ARCHITECTURE behaviour OF lifo_datapath IS BEGIN data_processing: process(clk, nrst, count_down, count_up) -- size of mem is 4 depth and 4 bits width type mem_type is array (0 to 3) of std_logic_vector(3 downto 0); variable stack_mem : mem_type := (others => (others => '0')); variable stack_ptr : integer := 3; begin if ( nrst ='0') then stack_ptr := 3; --stack grows downwards. full_signal <= '0'; empty_signal <= '0'; D_out <= (others => '0'); elsif(rising_edge(Clk)) then --check if push has been pressed/push signal has been received if (count_up = '1') then --data gets pushed/written into address when push signal comes stack_mem(stack_ptr) := d_In; --because a stackaddress got filled with data we got one less stack now stack_ptr := stack_ptr - 1; end if; if (count_down = '1') then --data gets read from the stack D_Out <= stack_mem(stack_ptr); --because a stackaddress got emptied we got one more stack address now stack_ptr := stack_ptr + 1; end if; --control signal to signal if stack memory is full or not if stack_ptr = 3 then empty_signal <= '1'; full_signal <= '0'; elsif stack_ptr = 0 then --when stack_ptr = 0 all stack mem are full and gives full signal empty_signal <= '0'; full_signal <= '1'; else empty_signal <= '0'; full_signal <= '0'; end if; end if; end process; END behaviour;
a problem or error.
Used do-file
#data-path lifo#
restart -f
#reset it once first
force Clk 1 0, 0 50 -r 100
force nrst 0
force d_in 0000
force count_down 0
force count_up 0
run 100 ns
#one datasteam in
force nrst 1
force d_in 0000
force count_down 0
force count_up 0
run 200 ns
#one data stream out
force nrst 1
force d_in 0000
force count_down 0
force count_up 0
run 200 ns
#first datastream in, total runtime 700 ns
force nrst 1
force d_in 0001
force count_down 0
force count_up 1
run 200 ns
#second datastream in
force nrst 1
force d_in 0011
force count_down 0
force count_up 1
run 200 ns
#third datastream in
force nrst 1
force d_in 0100
force count_down 0
force count_up 1
run 200 ns
#fourth datastream in
force nrst 1
force d_in 0101
force count_down 0
force count_up 1
run 200 ns
#fifth datastream in, test to see what will happen
#force nrst 1
#force d_in 1001
#force count_down 0
#force count_up 1
#run 200 ns
#first datastream out, total runtime 1500 ns
force nrst 1
force d_in 0001
force count_down 1
force count_up 0
run 200 ns
#second datastream out
force nrst 1
force d_in 0011
force count_down 1
force count_up 0
run 200 ns
#third datastream out
force nrst 1
force d_in 1100
force count_down 1
force count_up 0
run 200 ns
#fourth datastream out
force nrst 1
force d_in 0010
force count_down 1
force count_up 0
run 200 ns
#fifth datastream out, total runtime 2300 ns
#force nrst 1
#force d_in 1010
#force count_down 1
#force count_up 0
#run 200 ns
