majd229
Member level 2
Hello,
If you have a DEF and tech lef, and you convert the DEF to GDS using Synopsys ICC2.
Then you modify the GDS quickly, but now need to have a matching DEF.
Is there a tool/way to read in the new GDS, and tech lef, and write a DEF?
You might say, just edit the DEF and re-export GDS instead of editing GDS. I cannot do that, as there are multiple people in the firm that have different tasks, and they're different teams that don't interface with each other. So that's why I'm looking for a GDS > DEF conversion. Then later on, influence the firm to do things correctly.
Thank you
Thank you
