shravanevana
Newbie level 5
I have a 36-port S-Parameter touchstone file and I have never used this before. I am supposed to look at the S-parameter curves using ADS. Can ADS do a 36-port S-parameter simulation?
Thanks.
Thanks.
From where did you get the S-parameter touchstone file for 36 ports ?
Yes, you can use "data items" palette.Select one -for instance S10P- and then change the name by clicking on the name attribute to 36,so you'll have S36P component and you should define your file
in it..
