Can this transistor work ?
zahrein
Full Member level 2
Transistor question ?
at the base junction. i have a capacitor connected to the
base(transistor) and a resistor is connected to the capacitor and it is grounded?
can this circuit work?
Re: Transistor question ?
what do u want to do? is it like a cap and a resistor is connected in series with the base terminal and then connected to the ground. is there some biasing too? like a voltage divider bias?
a schematic would be helpful
zahrein, do *you* think it would work? Why, or why not?
Please show us that you have thought about your homework questions, and then maybe we will help you!
No, you need the DC bias. I think you are confusing the property of voltage and it's rate of change with DC biasing. There is no way around the fact that a signal goes through a capacitor and the bias on the other side is a DC.
i agree with u kevin. but if u have an FET that maybe there would be some "self bias" and maybe the circuit could do something. but the person asking the question was probably referring to BJTs so i think that isnt a possibility. i wonder if such a set up will be of some use in the FET domain :?
If you ground the gate of a FET you get current. With a capacitor there is an open circuit at DC. I think there exists a small amount of gate current to make the FET operate. I don't think there is enough bias with a gate capacitor in the way. An open circuit will cause the gate voltage to equal the source voltage anyway.
if you have DC bias it can work
a resistor and capacitor..is he doing a RC connection b4 the base?
