Oct 19, 2018 #1 E eduardomiguel Newbie level 1 Joined Oct 19, 2018 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 6 Va=Vc ,i have no idea how much Id is , im stuck Attachments ex.jpg 37.7 KB · Views: 144
Oct 19, 2018 #2 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,422 Helped 14,749 Reputation 29,780 Reaction score 14,101 Trophy points 1,393 Location Bochum, Germany Activity points 298,107 In a first step, calculate node voltages with disconnected diode, determine if the diode will be forward biased (short) or reverse biased (open). If forward biased repeat calculation for paralleled resistors.
Oct 20, 2018 #3 C c_mitra Advanced Member level 6 Joined Nov 13, 2012 Messages 3,815 Helped 929 Reputation 1,860 Reaction score 922 Trophy points 1,393 Activity points 30,142 Is there a trick? What is so special? R1/R2=R3/R4; the potential at the two ends of the diode are equal and hence no current through the diode. Ignore the diode then. Current through the first part is 5/150; through the right pair is 5/300; total current is 5/150+5/300. Why you are stuck? Id=0; what is the real difficulty?
