Can not find RF signal substractor symble in ADS2002
jupitorcuu
Member level 5
chinaBJ
When I want to draw a feedback system diagram in ADS2002,
I canot find a component like substractor.
I want to one signal substract the other signal,and then output
Because it is a function like reverse-coupler(it copy from one main signal),but not a coupler.
What is it in RF?
Gemini1706
Member level 5
you need to do it in simulation just like you do it in the real world: inverse the signal (180 degree shift in phase) then add the two signals together using a 3-dB coupler.
To acheive the 180 degree you can create an s-parameter block that does not change amplitude, but changes phases by 180 degree.
jupitorcuu
Member level 5
chinaBJ
Thank you
/ Warning #1 - No thanks at Elektroda! Read forum rules before posting! /
mwpro
Member level 4
alternatives you can use symbolic defined devices.
