papanatas
Newbie level 6
Hi forum!
Just got my hands on this Japanese power supply thinking that it had an internal switch able to select 110 vs 220. Sadly it doesn't but apparently other versions of the power supply do have it.
After inspecting the pcb I have found that indeed does have a place for the switch but instead a jumper seems to select the voltage position.
Do you guys think I can simply remove this jumper and have it working at 220v?
Here's a few pictures:
This is the other model seen on the internet featuring a switch:
