can i send data by tcp/ip protocole by using microcontroller
anan1975
Member level 3
Noida india
Dear all,
Can any body suggest that is it possible to send data by one microcontroller to another micro/PC by internet protocole if yes then how?
Regards
Re: can i send data by tcp/ip protocole by using microcontro
You can use any micro controller with wiznet's chip ... take a look at w5300 datasheet...
it is possible!
but let's see
a hardware design that connects to sort of access point with simple microcontroller is hard, implementing a network protocol to connect to hardware(Ethernet, wireless) gets harder, programing a tcp/ip stack and layers adds to compications, filtering and forwarding your required traffic even gets more harder.
so I would stick with ready modules, rather than trying to make one myself, unless your microcontroller support Ethernet, tcp/ip.
But from your post I am guessing what you want to do is just have tcp/ip connection over a router, so for example on a pc a program/socket listens to a specific port and, micro contollers connects to that software via tcp/ip. if this is your case, you can look into ECN28J60.
