The project doesn't seem to make sense. You may want to clarify it's purpose to motivate someone to help. Generally, the memory capacity of a FPGA is much smaller than even of a small DDR RAM.
I want to built a "memory" based on FPGA, which can be plugged into the DDR2 slot. The memory has the "DDR2" interface. And I can use other "storage" device on it to save the data(not in the FPGA buffer). However, I know that the memory access speed does not really reach "DDR2". It does not matter.
Can I realize such kind of thing? Thanks a lot for your reply.
Yes I think, it should basically work. Using dual edge I/O cells (DDIO), you should be able a achieve similar speeds in RAM emulation as with a DDR controller based on the respective FPGA family. Because of the RAM latency, even access to a fast external storage medium (e.g. SSRAM) should work.
However, I don't think you can get reasonable density with the FPGA at least not with a significant hit to performance speed. After all, there is a lot of routing overhead internal to the FPGA (all them switch matrices and what not).
The performance is not cared by me. That's ok if the FPGA can realize the DDR protocol. If the interface can be realized, I think I can use several methods to save the data, such as FLASH or even through ethernet.
