Can anyone explain this about PIC Code??
ajex
Member level 4
Member level 4
Sri lanka
hello..
I have written 2 code using MPLAB C30 compiler and MikroC dsPIC compiler for dsPIC30F6014A..
two codes are like below..
In MPLAB C30>>
PORTDbits.RD1 = 1;
PORTDbits.RD1 = 0;
PORTDbits.RD2 = 1;
In MikroC >>
const char ONE = 1;
const char TWO = 2;
PORTD.ONE = 1;
PORTD.ONE = 0;
PORTD.TWO = 1;
I expected the same result form both codes.. But results as follows..
In MPLAB C30>> PORTD 1st bit(RD1) set as 1 (but i'm expecting 0) 8-O
In MikroC >> PORTD 1st bit(RD1) set as 0
Can anyone explain this???????
And after inserted a delay to MPLAB C30 code it gave the correct results as mikroC code (PORTD 1st bit(RD1) set as 0) ... :-D
like this>>
PORTDbits.RD1 = 1;
delay(10);
PORTDbits.RD1 = 0;
delay(10);
PORTDbits.RD2 = 1;
Is this happened due to PORTD register writing delay???????? can't believe it...!!!!!
Try writing to Latches instead of PORT
like this
LATDbits.LATD1=1;
I had read somewhere that for writing we should use Latches and for reading we should use PORT
