calibre redifine problem
qjt333
Newbie level 3
Newbie level 3
i am using ic5141 usr5 and calibre(ver.2009) but i have a problem.
when i start cadence(icfb &), i see following messages.
i try to solve this message but i can not that.
what's the problem? (the pdk is ts35pm)
\w *WARNING* defstruct: Redefining Structure _mgc_eview_globals.
\o function make__mgc_eview_globals redefined
\o function copy__mgc_eview_globals redefined
\o function mgc_eview_cleanup_master_tables redefined
\o function mgc_eview_set_master_cellview redefined
\o function mgc_eview_get_master_cellview redefined
\o function mgc_eview_get_master_pins redefined
\o function mgc_eview_get_master_propmap redefined
\o function mgc_eview_get_master_pinmap redefined
\o function mgc_eview_reset_master_pinmap redefined
\o function mgc_eview_init_parasitic_tables redefined
\o function mgc_eview_init_exceptions redefined
\o function mgc_eview_note redefined
\o function mgc_eview_warning redefined
\o function mgc_eview_error redefined
\o function mgc_eview_show_completion redefined
\o function mgc_eview_convert_to_string redefined
\w *WARNING* (def): macro MGC_EVIEW_CONVERT_TO_STRING redefined
\w *WARNING* (def): macro MGC_EVIEW_PARSE_PATH redefined
\w *WARNING* (def): macro MGC_EVIEW_REMOVE_SLASH redefined
\o function mgc_eview_sanitize_name redefined
\o function mgc_eview_place_pins redefined
\o function mgc_eview_get_symbol_terminal_0 redefined
\o function mgc_eview_get_symbol_terminal redefined
\o function mgc_eview_get_schematic_cellview redefined
\o function mgc_rve_cell_start redefined
\o function mgc_rve_cell_end redefined
\o function mgc_eview_remove_one redefined
\o function mgc_eview_get_master redefined
\o function mgc_eview_parse_property_spec redefined
\o function mgc_eview_map_property redefined
\o function mgc_eview_parse_properties redefined
\o function mgc_eview_set_inst_property redefined
\o function mgc_eview_apply_calibre_properties redefined
\o function mgc_eview_reset_properties redefined
\o function mgc_eview_parse_device_position redefined
\o function mgc_eview_parse_parasitic_position redefined
\o function mgc_eview_strip_device_prefix redefined
\o function mgc_eview_get_named_instance redefined
\o function mgc_eview_get_named_schinst redefined
\o function mgc_eview_get_schematic_device redefined
\o function mgc_eview_parse_path redefined
\o function mgc_eview_wire_pins redefined
\o function mgc_eview_connect_pins redefined
\o function mgc_rve_place_instance redefined
\o function mgc_eview_get_array_position redefined
\o function mgc_eview_place_noconns redefined
\o function mgc_rve_place_parasitic redefined
\o function mgc_rve_device_template redefined
\o function mgc_rve_parasitic_template redefined
\o function mgc_rve_get_highest_netname redefined
\o function mgc_eview_sanitize_netname redefined
\o function mgc_eview_get_net_id redefined
\o function mgc_rve_net_info redefined
\o function mgc_eview_cleanup redefined
\o function mgc_eview_dump_cell_map redefined
\o function mgc_eview_open_cellview redefined
\o function mgc_eview_open_pin_cellviews redefined
\o function mgc_rve_is_file_readable redefined
\o function mgc_rve_create_cellview redefined
\o function mgc_eview_parse_cellmap_file redefined
\o function mgc_include redefined
\o function mgc_eview_add_to_cellnamemap redefined
\o function mgc_eview_parse_cellmap_line redefined
\o function mgc_rve_annotate_cellview redefined
\o function _mgc_eview_setup_calview_dlg_cb redefined
\o function mgcCalDeviceAndParasiticPlacementCB redefined
\o function mgc_rve_setup_calview_dlg redefined
\o function mgc_eview_map_schematic_net_dlg redefined
\o function mgc_eview_close_mapnetdlg redefined
\o function _mgc_eview_mapnetdlg_close_cb redefined
\o function _mgc_eview_mapnetdlg_map_cb redefined
\o function _mgc_eview_mapnetdlg_select_snetlist_cb redefined
\o function mgc_eview_mapnetdlg_add_snet_to_list redefined
\o function _mgc_eview_mapnetdlg_select_snetbutton_cb redefined
\o function mgc_eview_mapnetdlg_select_snet_at_point redefined
\o function _mgc_eview_mapnetdlg_update_snet_cb redefined
\o function mgc_eview_mapnetdlg_display_snet_data redefined
\o function mgc_eview_get_calibreview_net_id redefined
\o function mgc_eview_mapnetdlg_get_device_term redefined
\o function _mgc_eview_mapnetdlg_calc_cb redefined
\o function _mgc_eview_mapnetdlg_plot_cb redefined
\o function mgc_eview_add_to_plotlist redefined
\o function mgc_rve_net redefined
\o function mgc_rve_annotate_netobjects redefined
\w *WARNING* defstruct: Redefining Structure _mgc_ccs_globals.
\o function make__mgc_ccs_globals redefined
\o function copy__mgc_ccs_globals redefined
\o function mgc_create_cdsspice_views redefined
\o function mgc_copy_symbol_view redefined
\o function mgc_create_cdsspice_cdf redefined
\o function mgc_parse_cdsspice_cellfile redefined
\o function mgc_show_cdsspice_info redefined
\o function mgc_eview_show_map_cell_dlg redefined
\o function mgc_eview_map_cell_dlg redefined
\o function _mgc_eview_map_cell_pins_cb redefined
\o function _mgc_eview_map_cell_terminals redefined
\o function _mgc_eview_browse_cellviews_cb redefined
\o function _mgc_eview_map_cell_dlg_cb redefined
\o function mgc_eview_write_device_map redefined
\o function _mgc_eview_cellmap_wizard_close_cb redefined
\o function mgc_device redefined
\o function mgc_layer_map redefined
